Repairable Dash?
MN71RT
First time on forum, as I continue to work on long restoration, any suggestions to consider if this dash is repairable or simply buy one of those "dashcaps"?
Probably not repairable, but it does not look too bad and is original. Leave it or replace with a new dash pad... the dash caps look cheap, imo.
MN71RT
Thanks for heads up, I have never seen a dash cap, but heard they are cheap.
fishpwr
Iowa
The dash pads are junk. I'd live with the crack, or I've installed a Dash with ABS core (thru YearOne) and a Dash with a steel core (Dashpad Pros). Both dashes fit and resembled the original pretty close.
