Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Senior Member
    Join Date
    May 2012
    Canada B.C
    Posts
    111
    Default 1970 challenger rear valance with exhaust cutouts
    I'm looking to buy a valance with exhaust cutouts and have seen amd and goodmark. Which one will be the best fit?
  2. #2
    Senior Member moparleo's Avatar
    Join Date
    Oct 2011
    So. Cal. Riverside area
    Posts
    1,213
    9
    Default
    AMD. All of their sheetmetal is superior to Goodmark.
  3. #3
    Senior Member
    Join Date
    May 2012
    Canada B.C
    Posts
    111
    Default
    Thanks I was about to get goodmark from summitracing.
  4. #4
    Senior Member
    Join Date
    May 2012
    Canada B.C
    Posts
    111
    Default
    Just got the valance and the right side is too long and the bolt dosent line up.
  5. #5
    Join Date
    Oct 2011
    Posts
    1,213
    9
    Default
    Are you comparing it to the other valance or to the mounting holes on the fenders ? Pictures sure help. Too long and doesn't line up really don't tell us much.
  6. #6
    Senior Member
    Join Date
    May 2012
    Canada B.C
    Posts
    111
    Default
    I put the valance on the car and on the right side where the quarter meets is not lining up.
  7. #7
    Join Date
    Oct 2011
    Posts
    1,213
    9
    Default
    Is it a small amount or a large amount? We can't see what you see. Even original factory sheetmetal sometimes needs to be fitted. No two cars are exactly alike.
  8. #8
    Senior Member
    Join Date
    May 2012
    Canada B.C
    Posts
    111
    Default Right side
    This is the side that I'm having problems with.
    Attached Images Attached Images
  9. #9
    Senior Member
    Join Date
    May 2012
    Canada B.C
    Posts
    111
    Default left side
    This side is fine.
  10. #10
    Join Date
    Oct 2011
    Posts
    1,213
    9
    Default
    Thanks. Much better with a picture. You say it is too long. How does the new panels' contour compare to the original valance? If it looks the same, the contour of the r/r fender may need work. If it looks different, the new panel will need work. Do you have much body/fender experience ? Has the car had possible repair to the fender in the past ?
