I have always used the oldschool way of figuring out carb size. It works really well, at least it does for me. This little rule of thumb is for stock or mild builds. Radical builds will easily handle more.
Take the cubic inches of the engine and double it. In your case, it is 340.
340 X 2 = 680 cfm
Example, I am running 528 CI in a medium build Hemi. I run two HP Holley 750's on a crossram. 727, 3800 converter, 410 rear, 31" tall tires, 3500 lbs and it handles it just fine. It actually lays down a better 1/4 mile number with 2- 1050 dominators, but I never run them on the street.
Keep in mind this for stock to mild. If you are pushing 375 hp then a 700 or 750 will work great. I am a fan of the Holley HP series. If you don't need a choke very often where you live, they are the ticket. Just my old 0.02
