73 brakes on 71 Challenger
challenger440
Santa Maria, CA
I've had some spindles laying around to convert my 71 challenger to disc for some time and am finally getting around to it. when I went to install the wheel seals for my new '71 style rotors, they wouldnt fit. long story short, I found I have '73 spindles and need to get '73 rotors, seals, etc. (Either that or new spindles now to match all my other crap I bought).
Any issue (clearance, steering, etc.) with using the '73 spindles and brake components? I would prefer to keep the '73 spindles and just exchange my expensive '71 to match them.
It doesnt seem like it would be a problem but want to be sure. One things that's nice is that the '73 components are 1/3 the price of the '71! I hope it will work...
the 73 used a larger inner brg & seal , as long as you can return all the 71 parts you will be fine with 73 parts , decide if you are going to mount the calipers in front or rear of the spindle as you will need different calipers & hoses , as I recall I usually mount the cailper in front & use the Raybestos hoses ending in 828
challenger440
Santa Maria, CA
The inner seal is definitely bigger but the bearings look the same. My calipers are set to go to the rear of the spindle so I guess I'll leave it that way. Glad everything will still work! Got the return for the 71 rotors approved and will order the 73's. Much cheaper too. Calipers come up as the same too which is a relief. Wont have to return those.
Speedracer3456
I put '73 Volare (A body) discs on my '71 Challenger and they work great, but you will HAVE to mount the calipers in the front. Just requires a switch in sides of the spindles. If you don't, the calipers will hit the shock on every turn. Alignment is not an issue, mine was able to be aligned within specs. E bodies have the calipers in the front regardless of year, if I'm not mistaken.
napaguy
western nc
71 brakes
hey i just finished putting discs on my 72 challenger. i bought a set of spindles that were suposed ro be off a 73. the few probs i ran in to. i mounted them in rear, used mostly 73 ebody parts except for inner bearing, used bearing for 72 drum, used 73 charger brake lines with a banjo bolt. brake lines did hit shock bolt, but if you set banjo close to caliper, turn shock bolt around where head is toward line, it will have just enough clearance. i've got the whole list and part numbers if you need them. also i made mine non power brakes. used master cylinder for 73-74 charger with non power discs-drum set up
Adrian Worman
England
There is a bearing adaptor sleeve to make 70-72 spindles the same as 73 on and it's made by Scarebird, have a look on their website, interesting reading
challenger440
Santa Maria, CA
I'm looking for the darn positioner clips for the stock caliper. Any clues? I found some for $35 (!!!) but read I might not even need them....is that right? Seems like they are the only thing holding the pins in place.
