Jetsurgeon
So I have been looking around, and all I can find for a port injection system for a small block Mopar is the Edelbrock Pro Flo 4? Is that really all we have to choose from for EFI? A TBI system or the Pro Flo?
Thanks, looking at the Terminator X control system with the Holley in tank EFI module to eliminate the need for a return line could be a potential solution. I would still need to use the Edelbrock Super Victor manifold and fuel rails, as there really aren't other options for a small block Mopar as mentioned, and get a set of injectors, but what about the other sensors needed for the Terminator X? The Holley universal throttle body has integrated TPS, IAC, and Air Temperature Sensors, but what about the other sensors? What else would I be missing? From reading the different forums it appears that the Terminator X ECU is more customizable than the Edelbrock Pro Flo 4 ECU, but Holley sure doesn't seem to make it easy to use their system on a small block Mopar....? I am building the engine with the help of the Hughes Engines team, and have posited the same question(s), and waiting to hear their recommendation(s).I'm putting the multiport EFI pieces together for my small block. Going to be using the Holley HP EFI Multiport Kit along with the Edelbrock Super Victor manifold Sal C mentioned. This kit offers a number of features including the ability to convert to distributerless ignition which I'm going to do. Should be interesting...
As you mentioned, not a lot of options for the SB Mopar. If you decide to go this route, best start getting things on order. Still waiting on some of the parts for this project I ordered a couple of months ago.
Holley EFI 550-500 HP EFI Universal MPI Retrofit Kits
Do you have a Mopar, Ford or other type engine you want to install multi-port fuel injection on? No, problem, the Holley HP universal retrofit EFI kits are designed to be used with any V-8 intake manifold. The kit comes with injector bungs and un-machined fuel rails so you can modify to fit any...www.holley.com
Thanks, lots of decisions....the Holley solution putting it all together with the dual sync distributor and the sensors that you have to buy (CTS, MAP, MAT) make it at least $700 more for the Holley MPI solution over the Pro Flo that comes with everything including the distributor...You'll just need a fuel pressure regulator and O2 sensor (but I think it's supplied with the Terminator X). The handheld comes with it. If you go thru efisystempro.com they sell everything, they are an authorized Holley dealer and the support is great. Scott will guide you thru it all...
Sensors are integrated in the throttle body except for coolant sensor which I think is supplied with the txThanks, lots of decisions....the Holley solution putting it all together with the dual sync distributor and the sensors that you have to buy (CTS, MAP, MAT) make it at least $700 more for the Holley MPI solution over the Pro Flo that comes with everything including the distributor...
Thanks, yes the sensors I believe are included, but the Tx is $1125 then $500 for a set of injectors, $470 for the throttle body and we're up to 2K without fuel rails or a manifold....add ~700 for those and you're at $2700 to build the Holley system where the pro flo has everything including the distributor for ~2K....trying to determine if there is any real added benefit to the added cost of the Terminator system for a mainly street car with no NOX or Boost....Sensors are integrated in the throttle body except for coolant sensor which I think is supplied with the tx
