seattlejanzen
- Joined
- May 6, 2019
- Messages
- 2
- Reaction score
- 0
hi all, new to this forum. I have a 1970 Challenger with power steering and the upper c-clip keeps popping off the shaft (see image) causing the steering shaft to retract a few millimeters which causes the crushcan to grind against the ignition housing (making steering very difficult and dangerous). I'm going to try grinding out the grove on the steering shaft that the c-clip slips into to try to make it harder to pop out but should there be any tension on that c-clip at all? I'm thinking that its just there to lightly hold the bearing in place. If there shouldn't be any tension any idea on how to loosen tension on the shaft? I've never messed with the steering on this thing.
any help much appreciate thx!
