Plastic repair
70cuda50
Colorado
Anyone use a plastic repair kit successfully on dash bezels or door panels. This Eastwood kit caught my eye. I have some repairs to make and may buy a better bezel that still needs a bit of work on broken tabs.
Rigid Plastic Repair Kit Black
budascuda
Somebody gotta come up with something that works good on plastics parts already!!!
If you end up buying the kit, could you please let us know if you got good results?
Thanks.
Grady Cain
NW Connecticut
I have used that product with decent results. Very easy to use. I used it to repair my original T/A rear spoiler (see "My T/A Restoration" post #121).
rklein71
Amarillo Texas
Plastic parts that are ABS can be repaired very easily. I repaired several bezels on my 71 Barracuda this way and several grills. You will need some spare black ABS plastic, either from broken pieces or just buy a small piece of black ABS plastic on Ebay for a few bucks. Cut up the plastic pieces and put them in a small jar that you can seal with a lid, pour acetone over the top of the pieces and let the acetone turn the plastic into a gooey mess. Then just use the goo glue as I call it to chemically weld the plastic together. You can even make small tabs and stuff with it. The repair is strong as the original plastic and very easy to sand down and repaint. By the way, I tried the same stuff on a door panel and the door panel is not ABS plastic, did not work. Rod
71RT383
CT
I have used " Plastex" with good results.
I have used another product called "PLastifix" which I prefer.
The "Plastifix"applicator tips were metal needles that worked better on projects where precision was wanted. IE: smaller tighter seem or needed more accurate placement.
The applicator tips on "Plastex" were plastic shaped cones that seemed to release more liquid than wanted at times, causing a wider dispersion of material on the repair, and at times wasting material.
Working on larger repairs or making tabs they both seemed to work well.
Hope this helps.
>PS: I have used them on the Heater/ac selector(rear broken tab and cable hold down), Lower dash trim ( fill in widened trim screw holes ), Tail light lenses ( used the clear to fix the broken red acrylic tail light tabs, worked very well. Picked up the red tone where they're joined). Used on other items as well.
Video
$38.95B0007LTXVO
IMPORTANT NOTE: Due to hazmat restrictions, we cannot ship this item overseas.
70cuda50
Colorado
Thanks. Sounds like more options available that actually work than I thought. Thanks everyone. Keep em coming if any more ideas.
budascuda
Board? you gotta be kidding me, I used to have subscription to the "Plastics on My Mind" annual report/magazine, Heh
Thanks, its more meaningful when a tedious subject is organized in this kind of format.
