727 Hard To Roll In Neutral .
70rcode
Ever since Rev Shift Patrn + Manual Only conversion, car is 3x times harder to push around in Neutral with engine off. With driveshaft disconnected, rolls easy normal. Any ideas what could be wrong or is this Normal after this mod ??...Thx for any help.
rogue
assuming the motor is not running i'm pretty sure the valve body shouldn't have any effect... did you also adjust the bands? If they're too tight they could be dragging on the drums.
70rcode
Thanks rogue !! That's an excellent suggestion....Don't know what why i didn't of that, but thx again.
oldkimmer
It very well could be the front band dragging if u set it too tight for the ratio. What is the front band lever ratio and what did u set it too. It most certainly will burn the band. Kim
