The trim that goes around the bottom of the rear window that holds the vinyl top
I do know there are studs that are underneath the trunk that holds the clips Just not sure how the trim comes off ?The trim that goes around the bottom of the rear window that holds the vinyl top
Thanks I’ll try thatUndo the bolts inside the trunk & behind the 1/4 windows & the trim should lift off .
