73 Clutch Pedal Bezels?
Steve340
New Zealand
From what I know the tapered pad will not fit the square pedals.
That is why I suggested possibly cutting the square pedal down to fit the tapered pads.
valkman
In the Triad NC
Well took a look at my pedals without the pads
As you all can see the pedal itself has tappered ends but
When shown with the tappered bezel for the 70-72 E Bodies it shows that they're much smaller, and when looking at the square 73 74 pads it doesn't look like there's any way that these bezels would work :(
Steve340
New Zealand
True they would only work if you cut the pedal pad down to the 70-72 size and used 70-72 rubber pads and bezels.
Have you checked the B body pads and bezels Quapman told you about?
I would not cut the pedals until you have checked all options out.
