FOR SALE 1970 340 block and parts
Cuda - Challenger Parts for Sale
  1. fk5aar
    fk5aar Well-Known Member
    280
    84
    Dec 2, 2015
    Contact Seller
    story goes this motor was tore down in 1980 on a 60k mile car and the. Never messed with. Missing one piston but other than that, mostly there. Supposed to be virgin block and steel crank never turned. Obviously has to be rebuilt. 915 J heads, regular not offset. Look at pics. Vin is 1b317802. Not sure what model this came out of. In Virginia right of highway 81. $1500 for everything. Pick up only so don’t ask. 540-797-8748/Text
  2. Eric Griffith
    Eric Griffith Well-Known Member
    163
    11
    Jun 25, 2016
    Just an FYI...what you have there is a 1971 340.
  3. fk5aar
    280
    84
    Dec 2, 2015
    Yes I should have said built in 1970 for a 71 car. Thanks. 9-23-70 to be exact
  4. Eric Griffith
    163
    11
    Jun 25, 2016
    Ya...the "340-4" ,and the intake manifold are also tell tale signs as well.
  5. Eric Griffith
    163
    11
    Jun 25, 2016
    Still A Great engine!
    • Like Like x 1
  6. fk5aar
    280
    84
    Dec 2, 2015
    That’s good, hope some puts it in a 71cuda w shaker, pistol, and billboard!
    • Like Like x 2
  7. aussiemark
    aussiemark Well-Known Member
    1,102
    467
    Nov 29, 2014
    Perth Western Australia
    It's a shame people pull things apart and allow them to get rusted it will probably require extra machining to clean up the rust off the crank journals and block bores.
  8. fk5aar
    280
    84
    Dec 2, 2015
    She ain’t too bad! Stores inside since 1980, guy was a drag racer. Second owner said the original guy pulled it from a 70 challenger. I told him it was probably a 71 but he is supposed to contact original owner and check for me just for shitz and giggles. More pics.
  9. Hemihead2
    Hemihead2 Well-Known Member
    105
    17
    Aug 1, 2017
    That intake is way later than 1971, hence the EGR and water neck rotation.
  10. fk5aar
    280
    84
    Dec 2, 2015
    Thanks Hemi! He had it sitting apart from the motor and threw it into the deal so I don’t believe it did come with the motor, but hopefully someone can use it. On Craig’s now so will probably sell soon
  11. Hemihead2
    105
    17
    Aug 1, 2017
    You bet! Good offering to the masses.
  12. Eric Griffith
    163
    11
    Jun 25, 2016
    Yeah ,the intake is Definitely Not a 70.
    The AVS was discontinued in 1970,and the Thermo quad started in 1971.
  13. Eric Griffith
    163
    11
    Jun 25, 2016
    Should be a Date stamp on it just behind the Thermostat housing area.
    Casting number should help too.
  14. fk5aar
    280
    84
    Dec 2, 2015
    1k for everything, Roanoke VA 540-797-8748
  15. fk5aar
    280
    84
    Dec 2, 2015
    Bump 900 for everything, 50$ ride to carlisle
