FOR SALE 1970 AAR/TA heads and rockers
mcmopar1974
I bought a 340 motor (non TA block) to put in my 1937 dodge truck for drag week, that starts in 3 weeks. When I took the motor apart, it had these heads and intake on it. Rather than destroy these heads, I would like to sell them and put a set of aluminum heads on it.They are still 73cc heads with the offset rockers. They don't look like they have had any work done to them. They have all the correct markings. I know this is my first post,but check me out on the H.A.M.B. as mcmopar, to see my post's and see I am reel. Not sure what they are worth, but I have to start some where $3000 obo. I am willing to deal, as drag week is not far off, if not sold they will go back on the motor.
Thanks Tony
340challconvert
Parsippany, NJ
Tony
Do you have pictures of the pair?
Could you please post a close up pic of the casting numbers, dates and top/valve side pics.
Both should be cast number 3418915 w the offset intake push rod holes.
Ad require location too.
413
What happened to the hardware and springs from the rocker shafts? Do you have the pushrods?
The heads look good.
Did you run that 340 they were on?
mcmopar1974
I have the hardware to bolt the rockers down to the heads, but not sure what springs you are talking about. I do have push rods, but they are not stock because of the fireball cam that was in it. No I did not run these heads. I bought the motor and took it apart to make sure it was good.
Tony
