SOLD 1970 Cuda 340 - 4sp #'s
440WB
Michigan
1970 BS Cuda 340 - 4sp #'s 8 3/4 .355 Posi - Rolling PROJECT Car ( Moving Sale )
NO FENDER TAG - NO BUILD SHEET - Interior Removed with some other parts starting the Rebuild process.
Yellow- Black Interior Black Vinyl Top. A/C Car many options. Low mileage third owner car from out west Original Paint.
Number Matching Motor + Trans + Body many Date Code nice PARTS Including SIX PACK SET UP Pistol Grip Shifter, Center Counsole, Bucket Seats, Rallye Hood. Rim Blow Steering Wheel. Polyglass tires on Cragers now.
Rallye Guages with Bezels, Dash Map Light Long Bar, Dual Mirrors, Vinyl Top, Rocker Gill Molding, Front Fog Lights, Fender Blinkers, FM 8 Track, Very Nice Rear Lights, Power Steering, Power Disk Brakes, Dual Exhaust, J Heads, Sway Bars Front and Rear + chrome bumpers, Original Mint set of Magnum Wheels with newer BFG Tires, Top of Doors Chrome Trim, Rear tail panel Trim, Nice Front Grille with chrome trim/ buckets with headlights, all Call out scripts Emblems. Full body complete wire harness's, Nice Working Seat belts. 5pc headliner bow set, interior trim, all plastic dash trim. Engine bay parts Painted with Engine K Frame. Original engine Bay Plastic Bottles - overflow, windshield res. Have all A/C Parts, condenser, compressor, lines, Acc. Pully's, All Plastic Dash In/Out Vents, have original solid exhaust pipes. Wheel Well Chrome trim, radiator shroud. trunk latch, hood latch with lever. Front Grille Frame is in Primer. Both Fenders are in Primer Inside/out
Only lower bottom 4" quarters are rusty, small dent in driver rear corner. Needs Trunk Pan. Straight Flat Panels of fenders, doors, quarters. Rest of Car is Solid. Engine needs Honed or Rebuilt, have original pistons/rods/crank/ cam/ J heads/manifolds. You need clutch parts, carpet, headliner, rocker sill plates.
Many Parts included - Some parts have been blasted/primered - Seat Frames/Springs are Painted. New Front Dash Full Pad ( not a cap ) New Black Legendary Seat Covers. New Front/Rear Tinted Windshield. NOS Front Grille Clear Lens. New side Markers Set. New upper door trim. New Gas Tank, New Clutch Fan, New Power Steering Pump, New Orange ECU. New Original Re-Cored Radiator or New Aluminum large core. New Hood Hinge. New Fender Gold Bolts. New Leaf Spring set. New Helwig Sway Bar Set front/rear.
Located 30 Miles N/E Detroit -
Will assist with Loading ( Possible Delivery )
Pictures can be sent
$16,500 with many more parts E body project cars - ( due to moving would prefer to dump out in this sale Make offer with the car.
Extra parts from 70 - 71 Cuda cars - front Full frame rail, inner fender/ patch's/ brace's, quarter panel patchs, front fenders/patch's, big block radiator surrounds, automatic trans humps rust free with Nice shifters linkages, sway bars, chrome window/door trim sets, bumpers, several bucket seat pairs, several valances, several door glass sets, dash frame with pad, New 71 cuda seat covers, 71 cuda front lower valance in primer, seat belt sets, several dash wire/fuse harness and rallye harness, sun visors, wiper arms, wiper motor, alternator, starters, engine parts, motor mounts, chrome door handles, NEW exhaust chrome Tip sets, Rallye Hood scoup Inserts, 70 - 71 side marker sets, bumper brackets, many body panel pieces, A pillars/cuts, door jamb sections, cross member sections with trans mounts, 71 cuda headlights with cups with backing plate sets, rear 11" finned brake drums complete, leaf springs, shock plates, extra sets of steel wheels 1969 -72, manifolds, carbs, heads, timing chains gears covers, pullies, rear seat set, clutch fan, center consol, kick panels, seat backs. several trunk lids and hinges, 2 Rim Blow steering wheels with other wheels, Manual steering gear box, suspension parts, Manual/Automatic Steering Columns complete assembly's. Cowl screens, wiper arm assembly. Horn sets, License backing plates, gas tank filler tube. K Frames. Many Door hinge sets. Bumper Jacks with Hooks. 4 sp peddles + parts, automatic trans.
Speedo Cables, Trans Cables, Heater control cables, standard gauge clusters with trim, 5 gallon buckets bolts, screws, clips, springs, parts, fender brackets, window track parts.
Please PM -
440WB
Michigan
Good Memory Matt!
Bought it with the intention to rebuild - she sat in my storage all this time while I worked on the other cuda cars.
