I looked up the specs in my 70 service manual
70 440 6 barrel manual trans. 70 440 6 barrel auto trans.
pt number 3438314 pt number 2875982
prestolte number IBS 4014 prestolte number IBS 4014D
Advance centrifugal distributor degrees at distributor
0 to 4.5 @ 650 RPM 0 to 5.3 @ 600 RPM
The specs are identical at 900 RPM and at 2400 RPM.
This is the only spec that is different, everything else is identical.
You could probably get away with running it, or try to find someone that could possibly recurve your distributor, or keep looking for the correct one.
I hope this gives you the information you need.
Ken
