HotRod20
This engine has been degreased, Magnafluxed, and bore gauged for size. It is a factory .020 over block with 10.5 compression pistons, floating rods, oil pan, pump and pick up, windage tray,valve covers, valve gear, factory 340 cam and lifters marked for correct postion.
Comes with #216 fan, 72 Thermo-quad #6090, correct #2100 Intake, and also included a 340 Torker intake.
Has 2.02 heads, one is a Z head and the other an O head. 10/10 Steel Crank, timing cover, waterpump and misc fasteners. Block has main caps.
Resized factory rods with paperwork, and paperwork, for the Degreasing and Magnafluxing with bore gauge checking. Main bearing and rod bearings were dated 2-70
Here's the VIN: 1B156652 and Engine Assy numbers: GW 340P 3352 0461 A (for.020 over factory block)
Casting date is 11-19-69
$1850.00 OBO pick up in Plymouth MI 48170 or I can deliver to Carlisle if prepaid.
US Postal Money Order or US bank Cashiers Check accepted, NO Pay Pal
Thanks HotRod20
Thanks HotRod20
