FOR SALE 1973 Cuda 340 Auto restoration started Petty Blue
wingman
True BS code 1973 Petty Blue Cuda, Auto, 340 up for sale. Work was is in process on the car with professionally installed new full left and right 1/4 panels with roof and rocker seams finished off. There has been new outer left and right outer wheel housings, left and right trunk floor dropoffs, one piece trunk floor, rear window filler, tail light panel, right trunk gutter, rear crossmember, left and right crossmember extensions all welded in. Welds all grinded and seam sealed. There has also been a new rear valance installed and prealigned at the seams of the 1/4 panels before welding to assure proper fitment. Previous owner had the rest of the exterior panels stripped and primed. They look nice and solid and need to be block sanded and reprimed . Cowl, firewall, inner fenders are very solid. Nice enough to just scuff and paint it. Only issue there is someone welded the battery tray to the inner fender. Frame rails and torsion bar crossmember are solid. Floor pan has some old patchwork that has been welded in along with framerail connectors. Can leave alone if you prefer as it is solid, but just depends on what your looking to do with the car. I'm including with the car another header panel that is rust free but needs a couple dents fixed. The header on the car is rotted and not worth fixing. Grille is busted on the car. Some items have been temporarily bolted back on the car for ease of transportation and to give you a better idea of what is there. I do have the front and rear glass mouldings and rear bumper fillers. Needs carpet, headliner, visors, A pillar mouldings, inside glass mouldings. Seats are proper for the car but someone had them recovered at an upholstery shop. They are not torn and useable if you wanted to. Door panels are in great shape. Dash is really nice except for 2 very small splits at the corners of the speaker grille. Car is an original Petty Blue Cuda, but it is not a matching number car. The 340 that it came with is long gone and someone replaced it with a 360 many years ago. Engine does turn freely. Car ran a couple years ago before being somewhat disassembled to work on. Car has had about 3,400.00 in new sheet metal put on along with over 7,000.00 in labor, plus the price of the car, so it is priced very fairly for what it is and whats been done. No fender tag or build sheet.Serious inquiries only please. Clean PA title. 13,900.00
