LA Small-Block Mopar Cylinder Head Casting Numbers
The casting numbers for small-block Mopar a seven-digit number, which is raised, and usually found in one of two locations. The first would be on the top of the intake runner, under the valve cover. The second location is on the underside of the intake runner on the cylinder head.
2268341 – 1962-1967, 318 LA-series small-block, 1.84/1.56 valves
2465315 – 1964-1965, 273 LA-series small-block, 1.78/1.50 valves
2532080 – 1964-1965, 273 LA-series small-block, 1.78/1.50 valves
2536178 – 1966, 273 LA-series small-block,1.78/1.50 valves, early
2658234 – 1966, 273 LA-series small-block,1.78/1.50 valves, late
2658920 – 1967, 273 LA-series small-block, 1.88/1.50 valves
2658920 – 1967, 318 LA-series small-block, 1.78/1.50 valves
2658234 – 1967, 318 LA-series small-block, 1.78/1.50 valves
2843675 – 1967, 318 LA-series small-block, 1.78/1.50 valves
2843675 – 1968-1969, 273 LA-series small-block, 1.78/1.50 valves
2531894 – 1968-1970, 340 LA-series small-block, 2.02/1.60 valves
3418915 – 1970, 340 LA-series small-block, 2.02/1.60 valves, 63cc-73.5cc, T/A
3418915 – 1970-1972, 360 LA-series small-block, 1.88/1.60 valves, 65cc-73cc
3418915 – 1971-1972, 340 LA-series small-block, 1.88/1.60 valves
3462598 – 340 LA-series small-block, Trans-Am, 63cc-73.5cc
3671587 – 1973, 340 LA-series small-block, 1.88/1.60 valves, 65cc-73cc
3671587 – 1973-1974, 360 LA-series small-block, 1.88/1.60 valves, 65cc-73cc
3769950 – 1975-1978, 318 LA-series small-block, 1.78/1.50 valves, w/ air pump
3769974 – 1975-1976, 360 LA-series small-block, 1.88/1.60 valves
3769973 – 1975-1983, 318 LA-series small-block, 1.78/1.50 valves
4006335 – 1975-1978, 318 LA-series small-block, w/o air pump
4027591 – 1975-1978, 318 LA-series small-block, 1.78/1.50, w/ air pump
4006337 – 1976-1976, 360 LA-series small-block, 1.88/1.60 valves, 2bbl w/o air pump
3671587 – 1976, 360 LA-series small-block, 1.88/1.60 valves, 65cc-73cc
4027569 – 1977-1986, 360 LA-series small-block, 1.88/1.60 valves
4027163 – 1977-1986, 318 LA-series small-block, 1.78/1.50 valves
4027593 – 1977-1984, 318 LA-series small-block, 1.78/1.50 valves
4027594 – 1977-1978 360 LA-series small-block, 1.88/1.60 valves, 4bbl w/ air pump
4027163 – 1980, 318 LA-series small-block, 1.78/1.50 valves
4027596 – 360 LA-series small-block, 1.88/160 valves, 66cc-72.5cc
4027596 – 318 LA-series small-block, 1.88/160 valves, 66cc-72.5cc, High Performance
4041001 – 318 LA-series small-block, 1.78/1.50 valves, w/o air-pump
4041003 – 1976-1981, 360 LA-series small-block, 1.88/1.60 valves, 2bbl van and truck, w/o air pump
4071047 – 1977-1978, 360 LA-series small-block, 1.88/1.60 valves, 4bbl w/ air pump
4071051 – 1977-1980, 360 LA small-block, 1.88/1.60 valves
4071051 – 1981-1983, 318 LA-series small-block, High Performance
4100405 – 1979-1981, 318 LA-series small-block 1.78/1.50 valves, w/ air pump
4100408 – 1979-1980, 360 LA-series small-block 1.88/1.60 valves, 4bbl w/ air pump
4100409 – 1979 360, LA-series small-block 1.88/1.60 valves, 4bbl w/o air pump
4100409 – 1979-1980, 360 LA-series small-block 1.88/1.60 valves, 4bbl w/ air pump
4323302 – 1985-1986, 318 LA-series small-block, 1.78/1.50 valves, Fast Burn, 56cc -65cc
4323345 – 1983-1986, 318 LA-series small-block, 1.78/1.50 valves, Police, roller, 69cc – 77cc
4323475 – 1985-1987 318 LA-series small-block, 1.88/1.60 valves, 69cc -77cc, 4bbl
