    Dismiss Notice
383 Rebuild kit
Engine Issues
  1. MN71RT
    MN71RT Member
    12
    Jun 10, 2010
    Long time no posts, wondering about 383 rebuild kits. I have a numbers matching engine and look forward to completing it. Any kits out there to avoid? Thanks!
  2. challenger6pak
    challenger6pak Well-Known Member
    3,447
    476
    Feb 27, 2011
    You could build a stroker and no one would know the difference.
    • Like Like x 1
  3. 71RT383
    71RT383 Well-Known Member
    94
    42
    Feb 26, 2012
    CT
    Someone else can offer more info based on their experience(s) with rebuild kits.
    Are you planning a cleanup/rebuild (due to Numbers matching), warm it over, modify, and so on ........?
    If planning a DIY ( and have the experience, proper tools, clean work area) then ; Before you buy a basic or even a more invasive rebuild kit , it would behoove you to know the exact condition of All the components within your engine.
    Take as many pictures as possible with notes.
    There are items to consider that can affect the overall build and budget, be it a DIY or Engine Shop build.
    The health of the entire block, cylinder bores, heads to name a few, can and will steer your build into a different direction and budget than originally planned.
    Do what you want, what you can budget and afford, and what will make you happy, just do it once and do it right !
    Good wishes on your project, post pictures and updates.
    • Like Like x 2
  4. MN71RT
    MN71RT Member
    12
    Jun 10, 2010
  5. MN71RT
    MN71RT Member
    12
    Jun 10, 2010
    Thanks for great input! Its been sitting since '85 in the garage. At the time it had 15K on rebuild. I'd rather pull it out and go through it or have it done (cleanup). Correct on finding out the condition of all parts first then move ahead. Will for sure need to budget at least 4K for this. I will post what I do, which would be next spring sometime..
  6. MN71RT
    MN71RT Member
    12
    Jun 10, 2010
    • Like Like x 1
  7. MN71RT
    MN71RT Member
    12
    Jun 10, 2010
    I am hoping to return it to stock condition if the engine checks out, but it will be runner not a show car, meant to be driven even if #matching. Got the Challenger R/T in '77.
    • Like Like x 1
  8. DetMatt1
    DetMatt1 Well-Known Member
    4,897
    868
    May 13, 2009
    How’d it run when you put it away all those years ago?
  9. 70Barracuda
    70Barracuda Well-Known Member
    53
    6
    Jun 3, 2014
    Only 15 k miles? id put it in and run it. I just did the same with a bike project I did. 1975 bike sitting since 85 with low miles. Started right up and runs great.
    IMO
    • Like Like x 1
