WTB 440-6 parts. Have trades?
Moparnascar
tulsa, Oklahoma
I need a pair of carbs, and a correct date coded intake before 9/69 or a correct aluminum intake. I have a original 440-6 V code Automatic car I am restoring. Car Build date is 9-3-1969 so i would like the dates earlier than that. I need a center carb 4376, rear carb 4383, front carb 4382. I also need a correct date coded 440-6 auto distributor.
I have been collecting parts for some time and I hae some stuff to trade or sell to make this correct.
440-6 10-30-69 cast iron intake
front carb 4382 2278 code
center carb 4375 3029 code
rear carb 4365 2278 code
looks NOS 1971 440-6 dual point dist #3436577 with vac advance #3438351
and a used 1970 340 dual point distributor #3438317
F-440 HP block.
1970 date 440 4bblintake
9-69 1970 340 block
4 340 J heads
2 906 440 heads
set of 8 original 426 hemi rods
halifaxhop
I just looked up the 44o dist is it 2875982 IBS 4014d that you need?
halifaxhop
All I have right now is a IBS 4014, not a 4014d, actually sold the last one over the weekend. They are hard to get a hold of if that is the one you need. If so I will keep a eye out have a bunch of prestolight cores coming in. PM the dist number you want. I do have a 2875764 which could be the one you need also. Really need the number you at looking for.
halifaxhop
That one comes up 70 440 6bbl a/t Not on my list but I have some cores that came in I have not logged yet. Does yours have the electronic advance? I thought you wanted one before 9/69 sorry for the mix up. I was thinking the car was late 69 not early 70.
halifaxhop
Here is some info from my sun cards that might help out.
1970 440-6 375 HP dist A/T 3438222 has the elec vac adv 3438222 M/T IS THE SAME CURVE, 440-6 390HP 2875982 (IBS 4014D) JUST FYI 3438314 (IBS 4014) STANDARD VAC ADVANCE AND IT HAS EXACTLY THE SAME MECHANICLE AND VAC CURVE.
THERE IS A GUY OUT THERE THAT REPOPS TAGS, FORGOT HIS NAME.
Moparnascar
tulsa, Oklahoma
Ok. Just to be clear. This car did not have a dist in it. I dont know what the correct number would be. But I think it is 2875982. I am going to rely on you guys that have the knowledge. My car rolled of the line sept 9 of 1969. 1970 cuda. V- code
halifaxhop
I come up with 1970 440-6 375 HP dist A/T 3438222 has the elec vac advance. What are you doing with the car, a driver, semi show want it to have the right parts if some one looks hard, 100 point restoration? There are a lot of ways you can go. Be prepared to spend some serious cash on that one even as a core.
halifaxhop
Hang onto that 71 vac advance you might need it for the 70 distributor they go 250 and up nos and they might not be good either, hate those things.
