The 2 heater box doors, after i removed the dry crumbled foam, I found a sheet of clear plastic between the foam and the doors. Should I remove this also, then spray the adhesive, or just spray over the top? I have never seen this mentioned before.
I emailed them with the same picture and got this back on the 24thGive Loretta a call at DMT. She will be able to tell you.
