Is there anything actually salvageable on this car?
I will get better pics in next 2 weeks for all to determine. Its is a convertible.. only 2 years made. 70-71
Could this be a 71 challenger? Rare challenger of only 83 produced. I did some research and they did not have yellow color in 70. Correct me if I am wrong. More pics today of it. There is nothing from behind the doors back. Cars rear end was cut off. If its a 1970 year there were only 378 produced. Anyone? Its also a 3 speed car.
1971 Dodge Challenger 6 Series JH & JL
Know your VIN?
Convertible
Get your instaVIN
Standard Specifications
Vehicle History Report!
Show Summary
Original Base Price $3,105.00
No. Produced 83
Body
Body Maker Dodge
No. Doors 2
Passengers
Model Number JH27
Weight 3,150lbs
Dimension
Wheelbase 110 inches
Length 191.3 inches
Width 76.3 inches
Height 50.8 inches
Front Tread 60.2 inches
Rear Tread 60.7 inches
Engine
Type Slant 6 overhead valve
Displacement 225.54 cu. in.
Cylinders 6
Bore & Stroke 3 13/32 & 4 1/8 inches
Compression Ratio-Std 8.4 to 1
Compression Ratio-Opt
Brake Horsepower 145@4000
Rated Horsepower 27.85
Torque 215@2400
Main Bearings 4
Valve Lifters Mechanical
Block Material Cast Iron
Engine Numbers
Engine No. Location Stamped on joint face at right corner, adjacent to number 1 cylinder bore.
Lubrication Pressure to all bearings excluding wrist pin
Carburetor
Type Single downdraft
Make Holley
Transmission
Type Synchronous in 2nd & 3rd
Drive Rear wheel drive
No. Of Gears 3
Gear Ratios
1st 2.95
2nd 1.83
3rd 1 to 1
4th Not applicable
5th Not applicable
Reverse 3.8
Clutch Type Single dry plate
Clutch Size 9.25 inches
