need 70 challenger hood scoop [4] [not stripped heads] insert screws... and one [un stretched bolt holes] insert for the factory r/t hood see pic of screws as they are very odd small head style thanks
May have the screws and will let you know if i do. Do you need the threaded insert for the plate screw or do you need the plate itself?
the threads are cast into the scoop not removable..i just need t he thin aluminum plate taht covers the scoop opening..one of mine has the holes stretched and the screws just fall thru..
Yes i understand they are cast in that is why i asked, thought maybe one of yours was broken out. I see which plate you need now and will let you know if that is the side i have
Sorry you have wrong information, that is not correct. Just by looking at the pics you can clearly see the difference they are unique to the right and left side. Go to your Chrysler parts book under section 15-03-83 and you will see the part numbers are 2998180 and 2998181 for the right and left side. I would not have mentioned they where different if i did not know by documentation they where. Hope this info helps in your search.
