gliderider-06
I have a 70 Barracuda that has a starting gremlin that I can't figure out. Everything was working fine on it until I pulled the lights out of it to paint the car. At first, it would not crank over with the key (after pulling all the lights out of the car), but it would start if the key was in the on position and jump the relay with a screwdriver.
Now the car is painted and have put the lights back in it and it still does the same thing with the exception that it will start with the key if the turn signal is on (either direction) It won't start if the brake pedal is pressed, only if the turn sigs are on. I am really stumped with this. was working fine. It has a new engine wire harness, electronic ign. starter, relay, ballast, ecm etc...
I have traced wires, swapped parts, added ground wires, jumpers checked plug connections.
Any suggestions would be greatly appreciated! PLease:help:
