1970 CUDA 440
Wiper Motor/Gear Assy ID # 3431077 7280 1819
Wiper Switch Assy ID # 2770380
When tested independently, each assembly conforms to specified testing protocols.
Therefore, it seems our problem is with connecting the two assemblies. For example, even though the wire colors from the recently rebuilt motor are correct, I question which ones have been connected to the gear housing and what position they should be inserted in the firewall terminal block. I also question, how the multi connector was matched to the switch (terminal B/U is not connected to anything?).
Can I obtain a connection wiring diagram?
