brake booster
Brakes
  1. 73cuda408
    73cuda408 Member
    7
    Sep 22, 2019
    I'm new to this forum,, so bear with me.. i need help finding a brake booster for my 73 cuda, pancake style. rebuuilt or somebody to rebuild it for me... I've been looking for a while
  2. 71RT383
    71RT383 Well-Known Member
    133
    66
    Feb 26, 2012
    CT
    Sent my 71cad plated PB Booster to "Booster Dewey Exchange " years ago was happy with the result.
    • Agree Agree x 1
  3. Steve340
    Steve340 Well-Known Member
    327
    80
    Sep 19, 2016
    New Zealand
    I had the Midland Ross booster on my car and changed it to the Ram Man Hemi booster.
    It is much more powerful than the pancake booster and is brand new.
    I got the installation kit off him and his Hemi master cylinder and I am very happy with it.
  4. 73cuda408
    73cuda408 Member
    7
    Sep 22, 2019
    So did you have to relocate/change your front and back brake lines ?? How much more room did that set up take up ??
  5. Steve340
    327
    80
    Sep 19, 2016
    New Zealand
    Mine was already a disc brake car so lines etc were no change.
    My car is a 340 engine and I found there was more room. Although the booster is slightly longer it is less diameter.
  6. Steve340
    327
    80
    Sep 19, 2016
    New Zealand
    I just had a look on his website and the whole kit including master is $525 with free shipping
  7. 67440NewYorker
    67440NewYorker Member
    11
    11
    Sep 8, 2019
    Michigan
    Booster Dewey for rebuilds. Just had one done by them last winter. Recommended them 100%
    • Agree Agree x 2
  8. 73cuda408
    73cuda408 Member
    7
    Sep 22, 2019
    The problem i keep wondering about is that i have big bump stick solid lift cam, and i wonder about booster holding what vacuum i have. I see these 8 inch boosters for me but dont know if that's works for my car.. Maybe i should give Deweys a call and end this ??? My car is also a oem front disc brake car.. just looked at it again and it would'nt be that bad to move brake lines..
  9. Steve340
    327
    80
    Sep 19, 2016
    New Zealand
    Only theory unless you measure vacuum. Pretty easy to put a gauge on it.
    • Agree Agree x 1
  10. ph23vo
    ph23vo Well-Known Member
    78
    18
    Apr 3, 2011
    seattle
    also most solid cams have decent vacuum if they have enuf initial timing!
  11. 73cuda408
    73cuda408 Member
    7
    Sep 22, 2019
    I'm running about 38 dgs inital timing on this cam, numbers are at dur 50 thousand 252/262 lift 542/555 with 1.6 rockers. It's a 408 if that matters. Original booster had fluid in it so i bought a booster from Ramman.inc . Now i have 1 good push on brakes and that's it,they will almost lock up but let up and try and push again almost nothing... Been doing something research and i'm going to install a vacuum pump i believe... anybody got a better idea let me know
  12. Cudakiller70
    Cudakiller70 Well-Known Member
    87
    30
    Aug 3, 2016
