Champion Aluminum Radiator
John h
Does Anyone know if you can use your stock shroud wit one of the champion direct fit 26" core radiators? I'm looking at a 3 core and I want to start with my own shroud and fan. I don't want to be forced to use electric fans.
John
Redo1973
John
Great topic. I did this without checking out the shroud. I put a clutch fan on and have yet to figure out adapting the shroud. I found an issue with alignment but it could be because of the clutch fan. My 340 still runs at a fine temperature without the shroud and am tempted to fabricate something. I'll be watching if others have a solution.
rklein71
Amarillo Texas
I gave up on getting a factory shroud to fit my champion radiator and went with a Ford Contour electric fan.
CCKen
FEBO Vendor
FEBO Vendor
Take a look at Cold Case Radiators. You can use the factory shrouds on the radiators.
Two row 1-1/4" tubes
