FOUND. Door panel part question
SFEbody
Los Angeles CA.
Does anyone know where to buy, and what is it called??? I am referring to the plastic insert between arm rest and into a 70 Challenger door panel. White specifically?
Thanks in advance.
Brian
No, but easy to make if you must have it.... I don’t think it is visible through the door handle opening.
Edit: My bad, I thought you were referring to the white rectangle on the back of the door panel.
SFEbody
Los Angeles CA.
I am referring to the part that has 2- large metal screws that go down into the door frame and the lock button goes through it? I hope this helps see photo red arrow
rbbruno3
upstate , NY
No problem Matt I only have one metal one I might have plastic ones but go ahead and make a deal if you if you want. Thanks for handling this the correct way :thumbsup:
DetMatt1
Would you believe that I have 3 metal and 3 plastic and they’re all the same side? One white in each though...:lol:
Sorry man but maybe @rbbruno3 has the other side and between the 2 of us we can hook you up.
rbbruno3
upstate , NY
I found 3 plastic ones for Cuda, the metal one is for a Challenger but I haven’t found that one
SFEbody
Los Angeles CA.
Matt I will take the white metal one... let me know what you need for it shipped to 91354
RBBruno if you have the opposite side from Matt same to you please
Brian
DetMatt1
Brian
Will do, I’ll get with you tomorrow on it.
