How do I remove a v groove pulley from my alternator to install a billet serpentine?
mopar440dad
I just bought a billet serpentine pulley set up from 440 source and can't figure out how to remove the alternator pulley and install the new billet one without damaging it. Any information would helpful. Thanks:help:
two types , most have a lip behind the hex nut so you remove the hex nut & there is a special puller that grabs onto the lip & pushes on the shaft , the second type has a tapered shaft & a keyway , if you put the nut most of the way back on & tap on the nut with a hammer it will slide off
mopar440dad
Thanks Chrco Psycho, I was able to find the special puller and successfully got the old pulley off and the new one pressed on.
