Feb 10, 2021 #1 Cratos Well-Known Member Joined Sep 11, 2018 Messages 387 Reaction score 59 Location Sunny Florida I need an ignition only on wire to use as a trigger for gauges but not on in Acc mode cant seem to find one under the dash.
Feb 10, 2021 #2 Adam Well-Known Member Joined Dec 25, 2012 Messages 1,642 Reaction score 697 Location Washington What about the power wire to the stock gauge cluster, going into the cluster voltage regulator.
Feb 10, 2021 #3 Cratos Well-Known Member Joined Sep 11, 2018 Messages 387 Reaction score 59 Location Sunny Florida witch color is it? must be hot only in key on not Acc
Feb 10, 2021 #4 72RoadRunnerGTX Well-Known Member Joined Jan 8, 2013 Messages 193 Reaction score 114 Location Shoreline. Washington Dark blue with a trace at the brake warning light is IGN1, switched power ignition run only. Can also get that at that circuit at the ignition switch Molex.
Feb 10, 2021 #5 Cratos Well-Known Member Joined Sep 11, 2018 Messages 387 Reaction score 59 Location Sunny Florida ok Ill look for it ( man i am tired of crawling under the dash !
Feb 11, 2021 #6 C Chryco Psycho Well-Known Member Joined Dec 28, 2008 Messages 4,441 Reaction score 2,081 Location Panama IIRC the black wire to the gauge voltage reg is the one you want .
Feb 11, 2021 #7 72RoadRunnerGTX Well-Known Member Joined Jan 8, 2013 Messages 193 Reaction score 114 Location Shoreline. Washington The voltage limiter for the factory gauges is powered by a black wire however this wire is on the Accessory ignition switch circuit.
