gaddy 69
hi im installing a msd 6al in my 70 challenger and need a switched hot wire can i use the old + side coil wire
yes i see the two wires brown and blue but which one can i useBrown and blue wires going to the ballast resistor
The blue (ign 1,+12v ignition run only) wire and the brown (resistor by-pass, +12v cranking only) wire have to be connected together for aftermarket ignition systems requiring +12v while running and cranking.yes i see the two wires brown and blue but which one can i use
This is correct, if you look at the diagram the connection comes off of the 2 wires because they are connected at the BR. This is something that plaques everyone putting in MSD and/or EFI.The blue (ign 1,+12v ignition run only) wire and the brown (resistor by-pass, +12v cranking only) wire have to be connected together for aftermarket ignition systems requiring +12v while running and cranking.
