K Member Fit
Challenger10
Ohio
I’m going to be changing my 70 Challenger from a 318 to a 440 and I have found a B body big block K Member. Are the E Body and B Body K Members the same? Someone in the past has told me they were the same but I don’t trust that.
1971 and 1972 B body k frame is the same as E body. Earlier than 1971 B body k frames have a different steering box angle.
Challenger10
Ohio
Sounds good, thanks for everyone’s help. I’m in pretty early stages on this thing so I’m sure I’ll be asking lots of questions, I’ve even thought about running the RMS system on it.
HooToTheCore
Charlottesville, VA
B-body K frames don't route the sway bar through the center of the K frame the way e body K frames do. So there is that difference. 318 and 440 ebody K frames are the same, but may or may not have a skid plate.
Mark Selby
70 b-body K-frame indeed has the sway bar running through the middle just like the E-body’s..... steering angle is different and angles the steering shaft more towards the drivers door which hopefully will benefit me with clearance with a Hemi.....
I would not recommend the RMS over the factory system , at least drive one before you buy .
