Need Help/Advice . . .
Caramon311
Ft Bragg, NC
I still have a lot to learn, so could use some knowledgeable insight from the group. For the last month or so I have needed to drive like an old lady in my 1970 Challenger. I am by no means a
"speed demon" but if I press the accelerator more than 1/3 -1/2 way to the floor there is a single metallic -chink- and the car will slow down for a moment almost as if I hit the brakes, and will then start speeding back up. The car has a 383 and an automatic (slapstick?) transmission. I'm not sure if that would be something caused by the engine, transmission, electrical system, or even the throttle transmission lever/linkage.
Any advice would be greatly appreciated.
Check your accerator pump on the carb. Maybe it causes the hesitation which causes something else to make the noise.
DetMatt1
You explained it pretty good but still tough to diagnose without more info. Maybe a video with good audio.
Post a pic of your linkage to the carb. Maybe something is hanging up.
tonysrt
It could also be weak fuel pump not being able to supply enough fuel. Also make sure fuel filter is not clogged.
74 challenger
s carolina
pressing gas hard or slow, how long have you had the car? did you change anything?what do you call a moment? did you check vac lines. need more info
Dodgeboy
Winnipeg Manitoba, Canada
For my situation the throttle/tranny linkage was jaming against the underside of my air filter baseplate. A simple 1/2 inch spacer between carb and baseplate fixed it. The issue happened due to the eddy rpm intake is higher then stock, which angled the throttle lingage enough to touch the baseplate. It felt like under light cruse the peddal would get stuck. Hopefully you have a easy fix too
