New for PST in 2014 Mopar Greasable Pivot Shafts
PST
New PST’s greasable pivot shafts for the A, B, & E Body Mopars, these shafts are the perfect additions to our Polygraphite front rebuild kit or any performance suspension upgrade. These reduce friction as well as prolong the life of your Polygraphite bushings and allow for smoother travel throughout its range of motion. Kits comes complete with two greasble shafts, Polygraphite bushings, outer shells and grade 8 hardware
• Improves handling and corrects the loose feel caused by worn pivot shafts
• Allows for bind-free range of motion
• Recommended when installing a Polygraphite Front End
• Shafts are precision machined from high strength steel for years of abuse.
PST
The nice parts is that the portion of the shaft that presses into the bushing is larger than the stock original so you don't need to use an inner sleeve like your original. You press the sleeve and bushing into the control arm then just install the pivot shaft.
James
PST
Hello,
The set as seen is $109
James
