gary camper 440
- Joined
- Sep 1, 2020
- Messages
- 8
- Reaction score
- 1
i have 70 chall drum brakes replaced wheel cylinder went to bleed brakes and no fluid will flow out of both lines what could be the problem?
That was my first thought, the rear hose.Proportioning valve or a problem in the rubber hose down to the diff where the inner layer is broken down & blocking flow , you need to crack the brake lines & see how far the fluid does flow
