OEM Rear Sway Bar Frame Bracket Bushing
Daves70Chall
Since the frame bushing bracket on the rear sway bar is welded and doesn’t unbolt, are the rubber bushings pressed in and out? Searches don’t seem to turn up replacements or views of how to replace. Best way from those that have had experience??
moparlee
Mid Michigan
A few years ago I was able to find a set of NOS bushings for the rear sway bar. I squeezed the old ones out and squeezed the new ones in with a little lube. You are right, I don't think replacements are available.
Daves70Chall
Much appreciate. Might look at ways to modify the frame bracket to allow easy replacement.
