- Pro Street, 1971 Dodge Demon (Per the VIN), but car has Duster Grille and Tail-lights.
It is equipped with the following;
-Engine - Stroked to 471 Cubic Inches (offset ground crank - 2.2 journals)
-Block is 'O' Ringed
-Forged Mopar Crank - 4.38" Bore X 3.9" Stroke
-Eagle - 6.535" Rod Length - Steel
-Heads - Mopar Aluminum, Stage VI -Bowl Ported-'O' Ringed
-Valves - 2.20" Intake - 1.81" Exhaust
-Pistons - Weisco 13.5.1 / Race gas only! (RENEGADE 110 Leaded is perfect and less $ than vp)
-Wrist Pins - .990"
-Camshaft - Crower Hyd. Roller / Harland Sharp Roller Rockers
-Headers - Hooker Competition, Coated * Coating is starting to wear off in some places.
-Milodon - Dual Line, Swinging Pick-Up
-Milodon - Oil Pump, 8 QT. with Windage Tray, Baffling
-Milodon - Gear Drive
-Oberg Remote Mount, Oil Filter w Dash Warning Light
-Intake Manifold - Edelbrock RPM Performer - (Aluminum)
-Carb. - Holley 850 Dbl. Pumper
-Trans. - 727-with 'Dynamic' 3,500 RPM, Stall Converter, Trans. Brake, Line Lock, Reverse Manual Valve Body, Cheetah SCS Shifter
-Ignition - New as of 6/1/2016, MSD 6AL / Mopar Distributor
-Batteries - (Dual) - New as of 5/20/2016 - Rear Mount / Exterior Emergency Shut-off, located on Rear Back Panel
-Radiator - 'Be Cool' - Aluminum
-Rear End - Dana 60 with Spool, Strange Axels, Late Model 4.5" BP, F. Rotors, Ladder Bar Suspension, Coil Over Shocks, Frame Tied Roll Bar, with
'Halo' Cage. Car was certified before and since it's been a Street Car for the last 2 owners, it's never been re-certified. It should easily Pass re-certification, if you want to race!
-Tires - Mickey Thompson's Front & Rear.
-Wheels - 'Weld Wheel-Pro Star's', Front & Rear
-Gauges - 'Autometer', 160 MPH Speedometer, Vacuum, Water Temp., Oil Pressure - 'Liquid Filled' Series
-Tach. - 'Autometer', Sport Competition-10,000RPM with 'Playback'
-Body - Fiberglass Hood, Fiberglass Rear Deck-Lid, Lexan Side Glass & Lexan Rear Window Glass. Body is really straight except for 1 nickel sized dink on each side of the car & 1 small dent on passenger side front fender. Some of the factory lead work is starting to show at the factory roof seams, where the roof blends in with the upper 1/4's.
-The Paint is fairly good with typical scratches that can probably be buffed out. The car is Pink with Black 'Demon' side stripes, painted on.
-The Hood is a 'Lift-Off' Fiberglass with a 6-Pak Hood Scoop! The hood is painted Pink, with a custom, glossy black, wide stripe on the hood and over
the Hood Scoop! The Hoods in pretty good shape, but has a few small chips on the front edge and some small hair-line cracks at the Scoop opening.
-The Hood is held on by 5, Old Style Hood Pins.
-The Rear Trunk Lid is also a 'Lift-Off' Fiberglass and is held on by 4 1/4 Turn Dzus Fasteners. The Trunk Lid is in pretty good shape, but also has a few chips on the end, back edge, on each side corner.
-The Engine 'Fire wall' has been customized (smoothed over), so that no holes for where the heater core was, shows at all! Most all wires are hidden.
-Like all Mopars of the ’70’s era, the under hood area, is painted Pink, to match the exterior of the car.
-The Inner Fenders have been 'square' cut, for the fender well, Hooker Headers to exit and is also finished and painted Pink, to match the rest of the under-hood.
-Chrome Alternator
-Has a custom lite-weight, Aluminum Dash, that is painted flat black and has pink splotches, dabbed on it, for a custom look.
-The above mentioned, Auto-Meter, gauges are mounted flush, in the center, lower section, of the dash, in a horizontal black, insert section.
-Grant Steering Wheel with horn
-All turn signals, brake lights, headlights and Horn works!
-NO Windshield Wipers are on this car!
-Dana 60 Rear End w Strange Axels, Spool and 4.88 Gear
-Front Wheels & Tires are Polished, 'Weld' Wheel 15" X 3.5" Pro Stars with Mickey Thompson 26 X 7.50-15LT Mickey Thompson - Tires
-Rear Wheels & Tires are Polished, 'Weld' Wheel 15" X 15" Pro Stars with Mickey Thompson 32 X 17.50-15LT E.T. Streets -Tires
Asking $27,500.00, as is! Serious Buyers only! You couldn’t build this car for anywhere near the asking price!
**Car is a blast to drive and does not run hot! Low miles on engine, Trans, & Dana 60 Rear End.
Pm me here for inquires.
-Wrist Pins - .990"
-Chrome Alternator
