repairing 73 Cuda's tail lense
cudashark
Can a 73 Cuda's tail lense be removed from the housing without too much hassle? I have two tail lights, one that has a good lense (and damaged housing) and the other one has a good housing (and a broken lense). I thought I should check before I try
Challengaaah
You mean remove from the bezel? Of course, if it was put in then it can be taken out also. Just have to be careful not to damage the lens. It shoudn't be glued, there should be a thin foam type gasket between the two. I would first practice on the set with the damaged lens, to see how it fits together
cudashark
Thanks, I was worried that the lens might have been glued to the bezel
