Hey Guys, I wanted to get some opinions on my situation. I have a fresh rebuilt 440-6 that has about 500 miles on it. I originally put a 195 thermostat, radiator was a standard factory 26" 4 core with a fan shroud, viscous fan, and it consistently ran at 205 degrees at idle and low speed. Out on the highway it would run at about 208 and got as hot as 210 at one point. I replaced the thermostat with another 195 and got the same results. Just for experimenting I replaced the thermostat again with a 180, and the engine ran at 190 to 192 degrees. Continuing the experiment, I replaced the radiator and put a 195 thermostat back in and the engine ran around 200 instead of 205. I didn't get it out on the highway yet to see if it would go higher. The engine has always seemed to run just fine and it never acted too hot. It wasn't hard to start and it would shut off with no issues in all of the configurations I listed above.
Engine Details:
440 bored 0.030" (so 446 I believe)
aluminum Stealth heads from 440 source
Comp cams hydraulic roller cam XR274HR-10 1800-5800 RPM range (15" of vacuum at idle)
FBO ignition system, 34 degrees timing with mechanical advance, 48 degrees with vacuum advance also kicked in
Headers with 3" dual exhaust
10.5:1 CR
Cylinder pressures are all around 200 psi
Radiator is now aluminum (26") from US Radiator
thermostat is 195
water pump and neck are aluminum and from 440 source
the gauge set is dakota digital rallye set for the E-Bodies
Here are my theories/questions:
1) Could the aluminum pump and thermostat housing be tricking the thermostat? Do you think it is possible the coolant could be 200 coming out of the block and then drop to 195 over by the thermostat?
2) The gauge could just read hot.
3) Should I even care? If I leave it as is and it runs at 200....maybe I should just let it be?
Let me know what you guys think. Thanks for reading.
Engine Details:
10.5:1 CR
thermostat is 195
