    Dismiss Notice
Tachometer questions.
Electrical and Ignition
  1. bullet18
    bullet18 Well-Known Member
    171
    58
    Jan 4, 2017
    I can't seem to find much info on how to install a tach on my motor. Ive got a 78 motorhome 440 in my 70 challenger with a chinese hei knock off distributor. My dash doesnt have a tach but i would like one so i can set total timing and not accidentally float the valves. Where do most aftermarket tachs get wired to? The coil?
  2. Rich G.
    Rich G. Active Member
    43
    15
    Feb 7, 2019
  3. Adam
    Adam Well-Known Member
    1,006
    262
    Dec 25, 2012
    • Like Like x 3
  4. aussiemark
    aussiemark Well-Known Member
    897
    239
    Nov 29, 2014
    Perth Western Australia
    The after market tacho will or should come with some instructions (if new) there will be wiring for illumination you will have to wire this into your light bar so it comes on when you switch the lights on. there will be negative to ground, positive to switched power and negative trigger to the negative on your coil.
    • Like Like x 1
  5. moparleo
    moparleo Well-Known Member
    4,673
    455
    Oct 17, 2011
    I don't believe that the 70-71 Rallye tach's will work with electronic ignitions as Chrysler was still running point ignitions until 1972. An adapter is required. Need more research.
  6. Adam
    1,006
    262
    Dec 25, 2012
    The Mopar electronic ignition & distributor do work on a 70 & 71 cars with a Rallye tach. 100%, I have personally done this on both my cars, with no adapters. The coil does not know what type of dist is triggering it, and the tach gets it’s signal from the coil.
    I do not know if the MSD or other aftermarket spark systems work with the factory tach, I suspect they do, but I have never used them.
  7. bullet18
    171
    58
    Jan 4, 2017
    Thanks for all the info! I guess i can just use an aftermarket tach.
  8. AUSTA
    AUSTA Well-Known Member
    571
    167
    Apr 16, 2015
    PERTH WA
    If using aftermarket source 1 with settable high rpm trip point so that you can connect a light or if you fit an MSD at later stage you can set RPM limit
    • Like Like x 1
  9. bullet18
    171
    58
    Jan 4, 2017
    Will do. Thanks!
