73 challenger with a 383 stock electronic ignition distrubutor, 5 pin box, voltage regulator, 4 pin resistor, msd blaster 2 coil. We cannot figure this out. When all wiring is hooked up and you try and start the car, nothing, no ticking or anything. When you take the wire off the distributor side of the coil car will crank. When i originally got this car they had a wire from the positive battery post and an alligator clip you would clip on the same side of the coil as mentioned above. What gives. Is it because of the 12 volt coil. would changing to a stock coil fix the problem. Thanks for any help.
