Latest activity
  • Challenger RTA
    Challenger RTA reacted to topbanana73's post in the thread Shifter lamp with
    Like
    Like
    Maybe bad socket?
  • Challenger RTA
    Challenger RTA replied to the thread Shifter lamp.
    Not that this is your problem. Some LED's are polarity sensitive.
  • Challenger RTA
    Challenger RTA reacted to KlsCuda's post in the thread Blown rear end? with
    Like
    Like
    Update: This morning I pulled the wheels and brake drums off. Everything looks good there, I checked u joints and those are good. Also...
  • KlsCuda
    KlsCuda replied to the thread Blown rear end?.
  • maxb
    maxb reacted to Challenger RTA's post in the thread rear height with
    Like
    Like
    This might help.
  • maxb
    maxb replied to the thread rear height.
    But I think if I go with a 1" taller tire, my axle (rear of car) will be 1/2" higher and I'm trying to bring down the car height.
  • Katfish
    Katfish replied to the thread Shifter lamp.
    That connector to body ground is marginal. I installed an LED Bulb and it wouldn't work. I ended up soldering a wire to the socket...
  • maxb
    I think your car height is perfect----I'll aim for 26" or so. thanks
  • T
    topbanana73 reacted to scar426's post in the thread Console Fit Problem with
    Like
    Like
    mine has the same bow in the same approximate location, but no crack.
  • T
    topbanana73 replied to the thread Console Fit Problem.
    Same here, maybe from prior owner trying to access the bulb by bowing it in lieu of taking off top plates. I’m having the same issue...
  • T
    topbanana73 reacted to Chryco Psycho's post in the thread Console Fit Problem with
    Like
    Like
    You could epoxy a small diameter steel rod under it to support it & epoxy it from below
  • T
    topbanana73 replied to the thread Shifter lamp.
    Maybe bad socket?
  • T
    Thanks what I did do is temporary plug the lamp wire unattached to the acc fuse tab and no light. Tried 2 bulbs. Stumped…
  • T
    topbanana73 reacted to Challenger RTA's post in the thread Shifter lamp with
    Like
    Like
    Shifter lamp, dash light, brake and tail ight, headlight and others are grounded through the chassis ground. Chassis just one big wire!
  • T
    topbanana73 reacted to pschlosser's post in the thread Shifter lamp with
    Like
    Like
    the lead with the orange wire? I believe so, the "slap shifter" assembly is screwed to the frame and is grounded that way. The plastic...
