Latest activity
  • Challenger RTA
    Challenger RTA replied to the thread Slow Start.
    I had this happen again a little more than month ago. Car battery would not seem to charge all the time. OK no big deal I'll go get an...
  • pschlosser
    pschlosser replied to the thread AC vents in Non AC dash.
    I'm gonna avert my eyes and not watch, if that's okay. your dash pad looks really nice as it is.
  • Challenger RTA
    So now for the rest of the story. I Don't Quit! I'm smarter than a rock, I think! So like I said I know the battery is good. Check...
  • Challenger RTA
    I know I mentioned this before. It's like the fifth wheel you don't think about it until you need it. Your Spare with no air or not...
  • L
    larry4406 reacted to Sal C's post in the thread Restoration begins on a '71 Barracuda with
    Like
    Like
    Panel check really helps to see what your bodywork looks like... This is at 220
  • L
    larry4406 reacted to MoparCarGuy's post in the thread Console Fit Problem with
    Like
    Like
    Most consoles have the bulge problem and often crack in this weak area. I converted my auto console to a manual console and, at the same...
  • Katfish
    Katfish replied to the thread AC vents in Non AC dash.
    All of the metal frames for the dash pads have the cut outs in the metal for the AC vents. I'd think you could carefully cut away the...
  • Challenger RTA
    Challenger RTA reacted to gtw940's post in the thread Slow Start with
    Like
    Like
    I have a, probably not so good GRD from alternator to the block. I think i will be cleaning some mounting holes also!
  • Challenger RTA
    Challenger RTA reacted to Katfish's post in the thread Shifter lamp with
    Like
    Like
    That connector to body ground is marginal. I installed an LED Bulb and it wouldn't work. I ended up soldering a wire to the socket...
  • 440 challenger
    I have never seen a Cuda 340 that could not spin the tires with a 3.23 gear. Are you absolutely sure that you have 3.23's installed? Is...
  • G
    gtw940 replied to the thread Slow Start.
  • D
    don selleck reacted to Katfish's post in the thread rear height with
    Like
    Like
    Might be easier to just add lowering blocks? Mine is around 26.5, don't like to see top of tire. https://postimages.org/][/url]
  • Mopar Nut
    Mopar Nut replied to the thread Rocker arm kits.
    I used these with my Trickflow 240 heads on my 383. 1.5 ratio.
  • Mopar Nut
    Mopar Nut reacted to MOPARMITCH's post in the thread reproduction fender tags with
    Like
    Like
    I did not check. He did a dash vin plate for me since mine got destroyed...
  • MoparCarGuy
    MoparCarGuy reacted to Joeychgo's post in the thread See what you missed emails with
    Like
    Like
    and just like you were told on FABO, you change those preferences HERE: https://www.forebodiesonly.com/forum/account/preferences
