70 TA Challenger spacesaver mounting location
KennyCuda
I was putting my space saver back in my TA today and dont remember if it mounted to the first mounting hole or the higher one up I put it in the lower one as you look at the back of the car. I have it in but now there's no room for the hook right now it jact laying on the spare. Ive seen the hooks mounted under the tire in the front which I can't do there no room on the threaded rod that holds it down and ive also seen it mounted by the air canister which is correct and which hole does the mounting brakes go through.
KennyCuda
That's perfect thanks so much- I have it in wrong ill fix it tomorrow
KennyCuda
Couldn't wait thanks again Floyd, its actually the space saver from the car and original inflator im just missing the cap does anyone make the caps ?
KennyCuda
Thanks Floyd I messaged him--- Katfish the weight of the tire and it also has a spinner screw on top to hold it down
KennyCuda
Floyd what group battery is correct for the car is it a 24 ?
floyd
@KennyCuda - probably a group 24 (yellow cap) but your broadcast sheet will tell you for sure. I have a 71 340 car that was ordered with a group 27 (red cap).
