I know for sure all Cuda's use the same 2 holes for engine call outs on rally hoods, 340 383 440 440-6
On Shakers they used 3 holes but the 2 outermost ones are the same dimensions as rally hood call outs.
Example is my 440-6 call outs from my original rally hood fit the existing outermost holes in my OEM Shaker bubble, leaving the centre hole open.
I have little experience with Challenger hoods though, follow moparleo's advice and drill holes for the callout's you a
Ok, that makes sense about the 3 hole shaker engine call outs. The 426 hemi badges I have are 3 hole. does that mean they also make two hole Hemi badges?I know for sure all Cuda's use the same 2 holes for engine call outs on rally hoods, 340 383 440 440-6
I have little experience with Challenger hoods though, follow moparleo's advice and drill holes for the callout's you are using
Hood holes dimensions/location for 70 - 74 Challenger engine callout emblems. From what I see the back hole is about 11 1/2" back from the hood scoop opening. Need to fine tune I believe it is with in a 1/12" .085. place midway on vertical. 5.5" from edge of hood. Use a piece of paper to square up off of edge.
Anybody have a better answer post it.
