Are My Oil Pressure Readings Normal
sdcbowler
Have started my rebuilt 413 engine. It is still in the brake-in stage. When cold, oil pressure is above 50. As the engine heats up, the pressure begins to drop and settles at about 25 psi at idle (Approx. 900 RPMs). I brought the RMPs up to 2,500 and the pressure went back up to above 50 psi. Is this normal, or do I have a problem? The oil in the engine is 10W-40, Sensor and gauge are new. Do I need to go to a different grade/weight oil or use an additive?
Also, how many miles is the 'break-in, stage and what is the maximum spead I should go?
Thanks fellow members
Lube components,Prime engine,Use ZZDP additive. Proper break in on cam 2000 - 2500 for 30 minutes. Check oil filter cut open look for metal. At 2000 rpms oil pressure will be up. Don't let idle to much before break in.
Oil pressure of 25psi at idle sounds a little low even for 10W-40. The manual lists 45-65psi at 1000rpm. But the pressure going up with rpm is good at least. Of course we don't know your rod and main bearing clearances, etc. Hopefully you've added some zinc additive if it's a flat tapper camshaft. Personally I like to break an engine in with straight SAE 30 and a zinc additive. Usually figure 500 miles of break in before changing oil. Others may have different thoughts.
sdcbowler
Thanks much. Will take this to heart. I did lube the parts and primed the oil pump after assembly.
sdcbowler
Xcuda,
Thank you for the good advice.
Steve340
New Zealand
Don't baby the engine get on the throttle to bed the rings in just avoid flogging the ass off it.
I leave formulated break in oil in the engine for 900 - 1000 miles.
If using full synthetic don't change to it before the engine has done 1000 miles and is fully bedded in.
I did a saloon car engine and we left the break in oil in for 2 race meetings and no problems.
I agree with Chryco - the oil pressure is OK. So long as it builds quickly when you speed the oil pump up I see you being fine.
heminut
Deming, New Mexico
IMO you are fine 25 psi at idle is good & it rises with RPM , no problem .
I agree! I've seen engines that idled at 10 PSI with no problems. Yeah 10 PSI is a little unsettling to see but it's sufficient as long as the pressure goes up when the RPM's do also.
krazykuda
I had a similar problem with that on a small block and it turned out that the machine shop left out the oil galley plugs for the lifter bores that are under the camshaft thrust plate...
sdcbowler
I also believe it is fine as long as you used a stock oil pump. If u put in a high volume pump than it is on the low side
I did have a high volume oil pump installed. I figured that could be th problem so I replaced it with a stock pump. Once I start driving it regularly, I will see what happens.
Thanks much.
sdcbowler
That is so crazy. Good thing you notice it before you assembled, installed, and mounted it to the tranny. I think Mine is ok. I would have seen a mess of oil ont the floor when the engine was on the stand and I was priming the oil pump.
Thanks for the info. Another thing to be mindful of on the next rebuild.
volunteer
Kamloops, B.C.
Your readings are perfect - - IF you have 'fully grooved' mains. Biggest contributor to low oil pressure is bearing clearances.
Also, the sender may be out of spec. for your gauge. I recently did a magnum swap (rebuilt engine) in my old Ramcharger. I used the Magnum oil sender but my gauge barely registered. I put my old used sender back on and then my gauge could read it.
Same for the temp sender too. Btw, they look exactly the same. So…. try another sender if you have one.
Adam: I love your truck in you avatar. Always wanted one. You mentioned Ramcharger. So I settled for a 79 in the mid 80's. Sold it☹️ because the wife complained about climbing in when wearing a skirt. I said I have no problem with that. She replied: You don't where a skirt. I said I think I would look good in a skirt. She was not amused.😒 One time she said that we were lucky we were in it. As we were crossing an intersection. A driver in a Nova Went around traffic in the left turn lane only. Slammed into the front left tire. Ramchger didn't move. Totaled the Nove Knocked off a lug nut on the Ramcharger. They just don't build stuff like that any more. Sorry about getting off track.
But anyhow back on track. The Ramchager is relevant to this. I would say 99% of people do not understand how to run car's engine. It is ok to start a car and let it run to warm up, because it is at a higher idle. But once warm the idle drops. It is more than likely ok to idle a total half hour. After that I can be destructive. At idle the oil pressure is not there as it should be. I guess the 99% of the driver that let there car idle think it is a diesel truck. Diesel trucks are built different they can idle for long periods of time.
So case and point. The Ramchager I had a problem when I bought it. Not a big problem to me. The salesmen told it was used as a armed security vehicle in the mining industry. (When cleaning it up later I did find a few 357 rounds. I think they were serious.) The problem that was relevant it would smoke a little when first started. So got it took it home changed the valve seals and guides were ok.
That is also true for police cars the idle time is a engine killer.
