drivers side cable control routing for mirror
michael bucklew
how is the cable routed. tried under window--nope---to the front side--nope. there is a small clip that goes somewhere to hold the cables in place--where??? Also need to have location for hole in door panel to mount the actuator
terrywalker
On the front of the door in the hinge area, there's a hole the plastic clip goes into that keeps the cable from contacting the window when rolling it up or down. Here's some photos.
The first shows the clip on the mirror cable. The others show the location of the hole the clip presses in to. In a couple of the pics, I have a phillips screwdriver shank showing the hole.
Terry W.
michael bucklew
Terry W.
michael bucklew
very good....thanks-------have any idea where the hole for the actuator goes. I had one before restoration, can't remember where the hole is located
MoparCarGuy
The cable routing depends on if you are working on a 1970 or a 1971-74 E-Body.
The 1970 has a one-year-only bracket and metal clips. The 1971-74 has the plastic clip and metal clips.
The metal doors all have the hole prepunched for the remote mirror control.
Your interior door panel should have a hole for the remote "joystick" already there unless your car came with the standard mirror (see last picture).
Otherwise, you will see the location clearly marked on the backside of the plastic interior door panel. Open that up and you are golden.
michael bucklew
View attachment 122225 View attachment 122226
View attachment 122229 View attachment 122227
its a '71. good diagram
I had replaced my broken original mirror with one using the plastic clip. A day later the cable had moved and was catching on the front of the window, even though it was still clipped in. So I recommend finding or making the simple metal bracket, and you will only have to take the door panel off once.
Rons340
Tennessee
I was thinking that the last one I added had a template molded into the rear of the door panelwhere the control mounts.
