- Joined
- Oct 17, 2011
- Messages
- 6,949
- Reaction score
- 1,746
Why buy Taiwan made repros when you can get the highest quality remanufactured door hinges, using only original, Mopar made hinge cores.
I Remanufacture a complete line of Mopar application only door hinges using only new, high quality US made components. No import parts ever.
Over 15 years experience remanufacturing Mopar only door hinges.
I remanufacture the following hinge applications: 1967-1978 A-body, 1962-1965 B-body, 1967-1970 B-body, 1971-1973 B-body, 1970-1974 E-body. Most are in stock, primed,ready to paint and install. Or I can refurbish your old hinges with quick turn-over time.
Normally available for exchange or out right with a refundable core charge.
Refurbish process: disassemble and inspect for damage or excessive wear or rust pitting. Must meet my quality standards. If they pass inspection: then I remove door check pins( these are pressed in and must be cut out). Remove pins and bushings in upper hinges.
Square up hinge bodies. Bore & ream to fit oversized pivot pins in lower hinges. NO BUSHINGS.
Install new roller pins, by mig welding with new wave springs and refurbished rollers.
Tighten upper hinges.
Prime hinges with Automotive grade primer. Compatible with enamel or lacquer.
Install new Oil-lite bronze bushings and new pins in upper hinges.
Lube all pins and other moving parts with a Teflon lube.
Install pins and "S" lower pivot springs.
Chase all threads with proper sized thread chaser die.
Mark hinge install location on hinge bottoms.
Package in moisture proof, sealed heavy thickness transparent packaging.
Box up , enclose packing slip, install and adjust instructions from service manual.
Ship out by US Priority Mail.
FEBO members receive a 10% discount from Retail prices:
A-body 67-78 Retail $180.00 FEBO price $162.00
B-body 62-65 Retail $219.99 FEBO price $198.00
B-body 67-70 Retail $180.00 FEBO price $162.00
B-body 71-78 Retail $219.99 FEBO price $198.00
E-body 70-74 Retail $199.95 FEBO price $180.00
All prices are exchange plus refundable core charge
and Priority Mail shipping. $11.50 in the lower 48
also New factory key blanks and door springs are available.
Thank you for all of your prior and future business:
REMEMBER-MOPAR OR NO CAR
PAY-PAL, Postal Money Orders accepted.
