FOR SALE 1971 'Cuda 340 motor
Hemihead2
1971 340 motor VIN- 1B120490. Out of a 1971 Plymouth 'Cuda.
Here's what is what is INCLUDED- please read carefully so there is no confusion.
340 Block- Bored .030 and honed, line bore checked and in spec, cooked, cleaned, pressure tested. New freeze plugs and cam bearings installed. Ready to build.
340 J-heads- In as pulled FACTORY condition. Complete with all valves, springs, retainers, locks, rocker arms, shafts, etc. They look fine but have never been apart as far as I can tell.
340 steel crank- looks fine. Mains are .020 under from the factory, rods- std. (Pulled the factory bearings out of it on disassembly.) Maltese cross on block confirms factory undersize bearings.
340 Factory connecting rods/ 10.5 CR pistons. Rods are free floating and in good shape. Pistons are useless in this situation because of the recent overbore.
340 Factory 1971 CI TQ intake- Original to the engine. (Best factory 340 manifold from a flow standpoint).
Misc- Original WINDAGE tray, oil pan/ pick-up, 90* filter adapter, 16 push rods, front timing cover, original steel crank damper, lower two groove pulley and a set of (non-original) valve covers complete the package.
DOES NOT INCLUDE- Factory exhaust manifolds, Some exterior engine bolts, upper pulley, accessory brackets, motor mounts, etc.
Local pick-up is preferred but if you are unable to do so I am willing to load it all on a pallet to drop off at my local FASTENAL (after you pre-pay the shipping) for delivery.
$1,800
aussiemark
Perth Western Australia
Strange having it bored and honed without having the pistons normally the pistons are measured and then the block is machined to a predetermined clearance which will vary depending on the piston brand and type.
