FOR SALE 1971 Cuda Valance's + Other 71 OEM - MANY - Parts LIST + NEW
440WB
Michigan
All of these listed parts I have bought at least back in 2008
New and came from cars or parts boxes -
1) Front Lower Valance Original Steel ( one top corner weld - some stone dents with filler )
sanded - sealer - primer - filler - primer -
HAD NO RUST - ALL SIDE FLANGE TABS IN PLACE SHOWING PART NUMBER STAMPINGS - $275
2) Front Lower Valance Fiberglass NEW - $300
from the 1990's
3) Front above insert NEW Fiberglass - $250
from 2006
4) Front above insert Original part broken pass end - have some pieces to help repair - not exact fitment - $125
5) Front Fog valance Light sockets with Pig tails Set and Lenses Super Nice DRIVER
with ALL OEM MOUNTING SCREWS AND TOP BOLT with orange light bulbs in place - $290
6) Front Fog valance Light Lenses NEW Set Repo - $160
7) Rear Valance with Dual Cut outs NEW - Repo - $225
8) HeadLight's Mounting Plates with Stands OEM attached - mounted - $350
9) Headlight's stainless bulb retainer holders 4 each - $75
10) Headlight's NOS 2 each in the BOX - $100
11) Headlight's Original OEM - G.E. 4 each ( 2 standard bulbs with 2 bright light bulbs )
working set - $175
12) Bucket Seat Covers Set NEW 2008 Legendary - $575
13) Trunk Lid with spoiler cut outs NEW - $500
14) Trunk Lid with spoiler cut outs NEW with Factory Hinges Mounted
also been sanded - sealed - primered - blocked - filler - primer - blocked
ready for paint - $675
15) Front Windsheild NEW - $250
16) Rear Window NEW - $250
17) Coated Gas Tank NEW - $125
18) Big Block Copper Radiator Large Core - $225
19) 1971 Rebuilt 383 Engine Complete NO VIN NUMBER - 20 min Break in period - $4700
20) Rallye Gauges Set 70 -71 complete with clear plastic cover lense with holding clips with light tubes
clock cable + speedo cable + wiring connected in back for alt fuel with above 4 light bar
side switch panel woodgrain cover panel Dash plastic lower trim pieces both sides with radio cover
with heat control and bezel and cable Rallye dash wiring harness from fuze block to all connector points
glove box door map light ash tray housing plus door plus NOS cigar Lighter with light top speaker cover - $1600
21) Below Lower Dash Trim Map Light Panel 1970 over 40" wide custom grand coup or RT with clip retainers - $250
22) complete OEM jack set with base bumper hook and tire iron - NOT from a 71 just a nice clean working Mopar jack ( hook is longer than 71 ) $175
23) Interior Headliner Metal above Trim pieces around the windows and sides OEM original paint
No Rust in nice conditon = also have the U shape Clips with springs to hold headliner with 5 bows set - $600
24) Rallye Hood Scoup Set with inserts and acron nuts - $165
25) Front Chrome Bumper DRIVER nice shape 70-71 - $150
26) Rear Chrome Bumper Painted with bumperetts 70-71 - $175
27) Hood Hinge set OEM original with Springs 70 - 71 - $175
28) 8 3/4 Rear End Housing 56" wide with 10" Backing Plates 2 sets of axles have all nuts - .489 sure grip 1971 dated .323 ring gear set - NOT TOGETHER FOR INSPECTION - $650
29) 11" large Rear Finned Brake Drums Complete with springs pads - $175
30) Rear Tail Lights Complete Set OEM in Very Good Better Than Driver Condition with acron nuts - $725
31) Front Sway Bar Lower Control Arms Pair - $165
32) Front Factory Sway Bar complete with attachment K frame mount plates also control arm Links are in place
No Rust original Finish condition - $225
33) Rear Factory Sway Bar complete with Links and a Set of Shock Plates
No Rust original Finish condition - $275
34) Factory Frame mount ( tie down strap bar ) $45
35) Standard Gauge nice set - $160
36) Air Condition Vents set - $275
ALL PRICES ARE OBO PLUS SHIP PRICE -
POSSIBLE LOWER PRICES WITH COMBO PART BUYS -
TOO MANY PARTS TO HAVE ALL PICTURES -
WILL SEND PICS UPON REQUEST -
located N.E. of Detroit
Shelby Township Mi 48316
440WB
Michigan
NEW LIST PRICING
1) Front 1971 cuda Lower Valance Original Steel ( one top corner weld - some stone dents with filler )
HAD NO RUST - ALL SIDE FLANGE TABS IN PLACE SHOWING PART NUMBER STAMPINGS - $265
2) Front 1971 cuda Lower Valance Fiberglass from the 1990's NEW - $290
3) Front 1971 cuda above insert NEW Fiberglass from 2006 - $225
4) Front 1971 cuda above insert Original part broken pass end - have some pieces to help repair - not exact fitment - $115
5) Front 1971 cuda Fog valance Original Light sockets with nice Pig tails Set and Lenses Super Nice DRIVER with ALL OEM MOUNTING SCREWS AND TOP BOLT with orange light bulbs in place - $285 left and right
6) Front 1971 cuda Fog valance Light Lenses NEW Set Repo - $150
7) Rear cuda Valance with Dual Cut outs NEW - Repo - $215
8) 1971 cuda Original HeadLight's Mounting Plates with Stands attached - mounted - $335
9) 1971 cuda Headlight's stainless bulb retainer holders 4 each - $65 for all
10)1971 cuda Headlight's NOS 2 each in the BOX - $85
11) 1971 cuda Headlight's Original OEM - G.E. 4 each ( 2 standard bulbs with 2 bright light bulbs )working set - $150
12) 1971 cuda Bucket Seat Covers Set NEW 2008 Legendary - $550
13) cuda Trunk Lid with spoiler cut outs NEW - $500
14) cuda Trunk Lid with spoiler cut outs NEW with Factory Hinges Mounted also been sanded - sealed - primered - blocked - filler - primer - blocked ready for paint - $675
15) 1971 cuda Front Windsheild NEW - $250
BETTER NOT TO SHIP THIS VERY PRICEY
16) 1971 cuda Rear Window NEW - $250
BOTH WINDOWS FOR $450 with FREE rear
side glass windows pair
17) cuda Coated Gas Tank NEW - $115
18) Mopar Big Block Copper Radiator Large Core - $215
19) 1971 Rebuilt 383 Engine NO VIN NUMBER - 20 min Break in period - $4700 - OBO
20) Rallye Gauges Set 1970 -71 complete with clear plastic cover lense ( needs polishing )
with holding clips with light tubes has clock rear cable + speedo cable + wiring connected in back for alt fuel also top woodgrain cover -
side switch panel woodgrain cover panel with all 3 switchs
glove box door - map light - ash tray housing with cigar Lighter - $1600
21) E Body Below Lower Dash Trim Map Light Panel 1970 over 40" wide custom grand coup - RT with clip retainers - $250
22) complete OEM jack set with base bumper hook and tire iron - NOT from a 71 just a nice clean working Mopar jack ( hook is longer than 71 and works good ) $125
23)1970 cuda Interior Headliner Metal above Trim pieces around the windows and sides OEM original paint
No Rust in nice conditon = also have the U shape Clips with 2 rear springs to hold headliner with 5 bows set plus hook hold clips - $575
24)cuda Rallye Hood Scoup Set with inserts and acron nuts - $150
25) 1970 cuda Front Chrome Bumper DRIVER very nice shape NOt JUNK - no dents or dings no deep scratches ( perfect canidate to send out re chrome ) - $150
26)1970 cuda Rear Chrome Bumper is Painted with bumperetts - $165
27) 1970 cuda Hood Hinge set OEM original with Springs - $150
28) 8 3/4 Rear End Housing 56" wide with 10" Backing Plates 2 sets of axles have all nuts - .489 sure grip 1971 dated .323 ring gear set - NOT TOGETHER FOR INSPECTION - $550
29) 11" large Rear Finned Brake Drums they were turned and are Complete with new springs new pads - $150
30)1971 cuda Rear Tail Lights Complete Set OEM in Very Good Better Than Driver Condition ( NO PITS ) lense could use a polish also they come with acron nuts - $700
31)1970 -? cuda Front Sway Bar Lower Control Arms Pair - $160
32) 1970 cuda Front Factory Original Sway Bar
- Larger Hemi Performace package -
complete with attachment K frame mount long plates also control arm Links are in place
No Rust nice original Finish condition - $225
33)1970 cuda Rear Factory Original Sway Bar complete with frame mounts ( has undercoating splatter )
34) Factory Frame mount ( tie down strap bar ) $35
35) E Body Standard Gauge nice set with side panel with 2 switches and top cover - $150
36) 2 pc E Body Air Condition Vents Set - $275
3 pc E Body Air Condition Vents set - $475
3 pc E Body Air Condition Vents Set - $600
37) Hotchkis Sport Suspension Anti-Sway Bar Kits 2254 Front and Rear - ( selling as used paint is chipped from dragging around in storage all these years bought this set 2006) $375
440WB
Michigan
I'd like to see an image of #33 the rear sway bar setup. I'm looking for the axle sway bar bottom brackets the links attach to.
coming right up !
waiting for phone - cloud uploading pic's...
she looks just like this one -
440WB
Michigan
Im sorry - in reading your post again -
I SEE YOUR LOOKING FOR THE SWAY BAR BRACKETS - my bad - I only have these shock plates with a new set of links
pschlosser
Santa Rosa, California
Thanks for posting the images, @440WB yea, I was thinking on buying the whole setup if they had those plates. If you find them, I'm interested. They often wander off with the rear axle when it's pulled.
440WB
Michigan
lower valance fog light sockets/holders SOLD
gas tank SOLD
rear sway bar SOLD
440WB
Michigan
my last pair in nice shape - no rust
missing the washers/nuts
$110
