FOR SALE 1972 Cuda 340 4 speed numbers matching
brad echelson
1972 Cuda 340 4 speed matching numbers motor and transmission. This car has the fender tag and still has the build sheet under the driver seat. It is also the original interior in the car. The car has had the floor patched on the driver side has one small hole on the passenger side and then there's a few small holes in the trunk pan area and there's four places wh where a roll bar have been welded in that would have to be cut out and patched and also a section of frame rail in the front passenger side but I'm pretty sure I can get a replacement frame rail for it. I have quite a few parts and pieces that go with the car as you can see in the photo I don't have any other parts ,only what is pictured.. if you have any questions please call me directly and I can give you all the info that I know it's Brad at Phone number has been removed by staff. the car is located in Southwest Florida. I am asking $16,900 for the car. here's a partial list of the parts I have the short block with the crank and pistons and it new freeze plugs it was honest and looked like it had been gone through oil pan set of J heads valve covers intake and carburetor an air breather front and rear bumpers and Grill all the original seat belts all the Chrome window trims and wheel well opening rear lights all side light markers and the distributor ,transmission with the bellhousing and fork and 4 speed pistol grip shifter I think I have pretty much everything for the interior except for the radio. If you contact me directly I can get you any additional pictures and give you any information that I have I also have a set of 15 inch by 7 Rally wheels that I would sell but it would have to be separate I've got the center caps and beauty rings also for those all numbers are present on the car I've got the fender tag the radiator core support and the upper cowl location the upper cowl is pretty hard to read but I could catch the last two digits and then the trunk lip also is pretty hard to read but it's there thanks again
brad echelson
Found the trunk lip on the passenger side maybe 3 or 4 in from the where the corner turns going toward the flat part in the back I can't make it out clearly but I can see where there is some numbers stamped there
That number shouldn't match your VIN. Post a pic of the core support VIN.
These look good.
If you have this number on the trunk lip, someone added it.
brad echelson
Thanks the numbers or whatever I'm saying on the trunk lip are not clear enough to make out just look like something was stamped but I can't make it out clearly thanks again
72 blue 400
numbers on trunk lip is just a part number,not the vin,the vin numbers are stamped on the cowl and radiator support.also engine,tranny,dash,fender tag,door sticker if it still has one.
